1 - 15 of 15 Posts
So this is my first post on here but I am at my wits end as to whats wrong with my bike.. its been about a month of precious riding time and im ready to drop a match in the gastank at this point...
heres the deal.... 2007 600rr won't start/no spark at any cylinder..
have checked..
ecu
ckp
cmp
upper harness
bap is working
all nuetral/clutch/sidestand switches are good
no FI codes come up
everything seems to meter ok...
I knows its a vague desciption but throw some ideas at me!
Faulty engine start/stop switch?
Bas works... even leaned it all the way over to hear it trip the engine start stop relay, and alternatively bypassed it on another harness i tried
Oh and start stop switch seems to work and meters fine but will try to get ahold of another perhaps to try
fuse? I dont see that mentioned.
Make sure you are getting 12V on the common line at the coils, if its there then continuity check the harness to the ecu, if that's good then check the ground and power lines at the ecu, after that check your ignition pulse generator. Failing all of that it has to be the ecu that is buggered.
I have replaced the ckp(pulse generator) I have tried another ecu.. I have initial voltage at the coils.. grounds and powers all there.. I seriousley dont know what else to do
Ckp is installed correctly i dont thing you can install it improper lol... pretty fool proof;) and it is making good peak voltage...
D
Well, they can be installed backwards which wont let the bike start. It's a pretty common mistake.
So long over due, but just to answer the problem in case any one else has a similiar prob... My exhaust cam sprocket which is advanced on my motor ( I know this cannot happen on a stock engine) loosened off nad the cpu cuts off spark if the signals got oo far out of alignment;)
1 - 15 of 15 Posts
