1 - 20 of 46 Posts
Im debating on buying an arrow universal header for my 2008 cbr600. im pretty sure they will with most aftermarket slip ons, but i was curious to know...is the only difference between an aftermarket and an OEM header, that there is no Cat? if not, i might as well keep my oem header and just cut the cat out. unless there are actual gains to be made with an aftermarket one. thanks in advance
good aftermarket exh headers will be larger dia. (better flow).
will look better (stainless steel)
and aftermarket is lighter.
If you are going for looks at a budget price.....IDK, cannot really advise.
no experience in that.
BOTM winner 03/15
I cut out the cat and retained the stock headers. My bike is making as much power as those with aftermarket headers (more power in many cases actually) with an equally smooth power/torque curve.
You can compare my figures with those using aftermarket headers in the dyno results thread here http://www.600rr.net/vb/showthread.php?t=104896
Details of the cat replacement pipe can be found in this thread http://www.600rr.net/vb/showthread.php?t=476466
Or check out my build thread.
There was a lot to look through. What were the numbers?
BOTM winner 03/15
115 HP at the rear wheel, 45 ft-lbs torque.
The numbers on their own are good but the important thing is how they compare with the numbers of bikes with afternarket headers. Different dyno's will always give slightly different results but they are a pretty accurate indicator of how bikes compare depending on their mods.
IMO It's worth an hour of your time to research the topic thoroughly and read through the threads I linked and anything else you can find.
BOTM winner 03/15
Best comparison I can provide as an example is in my build thread. It shows results of two RR's (mine '08, another '10) which were dyno'd on the same dyno machine by the same technician.
The '10 has a full titanium system inc aftermarket headers and mine has stock headers.
Starts at post #412 http://www.600rr.net/vb/showthread.php?t=461386
so yours is a 2008 with a slip on cat delete and intake.
the other is a 2010 with full aftermarket exhaust (what brand?) intake?
do either have block off plates?
are both running the PCV?
and does the 2010 have a 2007/08 ecu or a ignition retard controller? (z-bomb or dynojet)
if not, its not really a good comparison, the 07/08 produces more power stock on stock.
honestly headers will only do so much, the cat delete will be fin for most people, i only bought arrow because it would cost me over 200 jst for a cat delete i figured what the hell spend the extra $ and just do it right.
also, i can put my stock exhaust back on and sell the arrow and akra if i ever decide to sell the bike.
well dkids the only one ive seen with a dyno graph and hes making more power than most with aftermarket headers in my opinion. Its also a cheaper option than arrow or other brands. Im sure honda has more money and people to throw at R&D than arrow or yoshi. The honest truth is theres no way to tell for sure. Every bike any dyno are slightly different and this all adds up to a couple horsepower.
Doesnt honda make the headers for the motogp bike? Maybe they know a little something that these other company's don't and that could/can help them in developing the headers for there line of street bike's Right!
A bigger diamater is not always better either for exhaust you can certainly go to big
BOTM winner 03/15
All the answers to your questions are in the links provided. From my build thread it would have been easy to click on the link to the build thread of the '10. Also, both bikes specs are listed in the dyno thread I linked above too. Last couple posts before the end.
However....Both bikes running a PCV, the '10 has a full titanium Leo Vince system & block off plates.UK (EU & AUS too) '09+ bikes weren't affected like the US ones so no ecu swap or Z-bomb needed iirc. It's a pretty darn good comparison imo.
What makes one way 'right' and another wrong? Don't feel like you have to defend your choice to buy Arrow headers, they're a great purchase and no one is trying to say otherwise, just that there are options available.
BOTM Winner 09/15
The 2010 is mine, full Leo Vince titanium system with K&N filter, and PAIR delete. I'm using the ECU it came with and have a full custom map using a PCV.
The full system I have made a massive difference to performance, but Dkid managed to get very similar results using the cat replacement pipe. For most people a full system isn't necessary, although the reduction in weight is always going to be a slight advantage with regards to real on the road performance.
im sure you got some good gains, but the 09+ has a disadvantage right off the bat (i have a 09)
right off the bazzaz site:
"Honda limited the power on the 2009-2011 model US spec CBR600RR, so that the peak power
is approximately 3 to 5 HP lower than the unlimited version of the ECU, and so that the power
peak occurs approximately 1500 RPM earlier. This was done via modified ignition timing values
in the stock maps of the US spec ECU.
Designed specifically for the US model 2009-2011 CBR600RR, the Z-BOMB allows US spec
bikes to get the full power as designed by Honda. At low and part throttle, the Z-Bomb does not
affect the ECU.
When the Z-BOMB is installed the bike will lean out slightly. For the best tune possible, we
recommend installing a Z-Fi unit as well"
http://www.bazzaz.net/instructions/O340i.pdf
BOTM winner 03/15
What you've quoted is only applicable to U.S '09+ models. It says so several times. You've clearly missed the point I made earlier about these two bikes being UK models. The UK '09+ models are not subject to the same power restriction as the U.S. '09+ models. Therefore the example I have given is a fair one.
BOTM winner 03/15
Thanks Steve, I was trying to use hard data rather than hearsay/opinion to give a comparison and our two bikes are the best example I am aware of to illustrate the point.
At least with proper results people can see and form their own conclusions. I see so many threads with titles like "which exhaust for my bike?" With a long list of replies where people just recommend the part they have on their own bike without saying why it's better than another part or why they chose it and what it has done for their bike.
im under the impression that the 09+ EU spec bikes have even more restrictions?
dont they have a 02 sensor in the cat?
1 - 20 of 46 Posts
