I just installed my integrated tail with watsens in the front. I have two 10 ohm resistors on the front with my watsens. The problem is before I installed my integrated tail, the blinking rate was normal. After I installed my integrated tail the blinking rate now is fast. I'm just curious if I need to install resistors in the back too because initally I thought you only need one set front or back. Thanks for the help guys.
I went thru the same problem all u got to is install the resistors
in the back instead of the front & the blinking rate will go back to normal
Cool thanks Moe, damn now I have to take everything apart again.
I know how you feel left mine with the fast blinking rate for a while :hello2:
