Hey guys. Looking for a quick answer. Have an 04 track bike and have a local guy with an 06rr engine. Is the ECU, throttle bodies and injectors off the 06 needed to do the swap, what can be removed from the 04 and hook up to the 06?
Engine needs work done. Valves and/or rings. This is the reason for the swap. Looking to swap motors and rebuild the 04 from the ground up. Thanks. T
Couple of things I have read. I can do the swap without the throttle bodies or ecu off the 06. The radiator plug is different but probably just needs the plugs swapped, no big deal. I guess the main question is can anyone confirm I don't need the ecu or throttle bodies to do this? Thanks. T
fast03600rr
i thought the ecm's changed from 03-04 and 05-06 but i dont know if the changed was significant enough for it not to work. maybe just fuel mapping was changed?
I guess the question is then can I put the throttle bodies off the 03-04 on the 05? T
