1 - 11 of 11 Posts
I'm wondering if a 4'x6' trailer bed area is long enough for a sportbike to fit on there, without the use of motorcycle rails (which allow the front wheel to overhang a few inches past the front of the bed). Or is 8' the minimum length needed to comfortably tow a sportbike when using a typical wheel chock rather than rails?
Thanks in advance!
I think you can fit two on the 4x6 trailer. Just make sure you get the tie downs.
i would feel safe to not use the tire chocks but if you made something even outta wood to hold it from wobling a little would be fine!
MotoGP NEWS Guru
That trailer I think is a 5 x 8 not a 4 x 6. I think the 4 x 6 is a tight fit, length-wise. I know someone who had a 4 x 6 with a ramp and they couldn't close the ramp because the wheel was impeding it from folding up.
MotoGP NEWS Guru
Oh yes, yes... 4 x 8. I have that very one. If you want to do a 4 x 6, you can, but you need rails. If so, let me know. I have two rails doing nothing in my garage. Heavy duty.
I've got a 4'x7' mesh floor trailer with ramp. I bought a $70 front wheel chock and Canyon Dancers and comfortably made a 800 mile trip. Just about the cheapest route you can go, cost me right at about $650 total
I use a 4'X6' with a wheel chock and its a tight fit but my 03 as well as my wife's R6 fit on it. I had to make extensions on the from to tie off with two bikes but it works. I use cheapo harbor freight wheel chocks and they work great.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=96349
I have to compress the forks on the both so the ramp gate closes. If your going to use it lots go for the 8' footer to save your suspension. We only trailer ours about 2 or 3 times a year to the track so no big deal for us.
Good luck,
1 - 11 of 11 Posts
