hello :)
me again :p
I feel like a motorcycle when running on idle at 3000rpm and other rpm,work on three cylinders.
Later, of course, does not even feel the difference: D
Bad fuel? or what the weather a little cooler? 15-20C (60-70F)
Or something else? or is this normal?
If not normal, how can I check or solve?
Motorcycle has power and is going well.
If necessary, I will shoot a video so that you hear. (if not ok) :D
Easiest way to find out use a spray bottle and spray water on all 4 headers if you got one that is not running right and getting hot its pipe will not show steam
I just touch them!!!! But my fingers are pretty tough.
If it's only 3 then bad plug/bad coil/bad coil pack are usually the problems.
I'm fairly sure the OEM one's are iridium...
