1 - 20 of 195 Posts
I just signed up for BRC and level 1 with my coworker. Anyone plan on going this day?
SupremeGC/Ryan.............white with GC sticker windscreen/Wht A*leathers
FlipDiver79/Marco............black bike/leathers
advan140......................gunmetal RR with red leathers.
Drewpt/Drew..................08 w/Movistar fairings towed by my gray 328i.
eRROc...........................flat black bike/red leathers/nicky laguna lid
iLLsYn'd/Jerico................tri-colored/black leathers
I'm also signed up for the level 1 and BRC for that day.
I'll look for that area...but never been there before. Can you park your cars right by the garages I've heard about?
Yep, parallel to each row of pits, is a row of parking spaces. Get there early since the pits are first come first served. Look for a black (honda of course) suv and black bike. See you guys there...
Kk. Ill either be borring my buddies white f-150 (POS) or my other buddies lowered 1500 with a black bike as well. Ill look for all of you.
Do they care if suits have a little rash on them? but no big tears?
On Full days, they would like to cram 4-6 bikes into each garage, but that still gives you plenty of space to hang out and relax in them.
I think they can actually fit two ambulances in each bay with walking room if that helps give you a visual for space??
You can't park your vehicle directly outside of your garage, but close enough that you can keep an eye on it if you need to. About 3 car lengths directly outside of your garage is plenty of parking for each bay. I've never heard of anybody's stuff ever getting messed with though, so I wouldn't worry too much. I've left ramps, tie downs etc., in the bed of my truck with it unlocked w/o incident.
I don't have any trackdays scheduled for May at all, so I'll have to consider this one.
Discussion Starter #19
My Coworker says they do not require safety wire anymore//
From Site
Motorcycle Requirements
Operational Kill Switch
DOT or Road Racing Tires in Good Condition WITH Valve Caps
NOTE: Check with Tire Vendors for Pressure Recommendations
Fully Operational Front & Rear Brakes in Good Condition
Mirrors Taped or Removed
Glass and Plastic lenses Taped or Removed
License Plate Removed
Wheel Weights Taped
Unplug or Remove Fuses for Headlight, Taillight, & Turn Signals
Speedometer Taped
No fluid leaks or broken controls
No safetywire needed. They are really helpfull over at the tech place. So if its a matter of wheel weights tape or something small like that, they will gladly help you out. I usually bring almost everything you might need for track prep so i'll help you out if you need it.
1 - 20 of 195 Posts
