1 - 10 of 10 Posts
ok, so my bike has been sitting for a few weeks, and now it won't start. last time I started it up (couple weeks ago) it fired up just fine. I tried to start it today, and when I turn the key to the on position, everything comes on, but no fuel pump prime. does this mean I have a bad fuel pump? is there anything else I should check? I checked the fuses and cleaned the connectors, and still nothing. please help!
T. BOTM Winner 10/11
Keep messing with the kill switch until you hear the fuel pump, and then never use the kill switch again
Check the relays under the upper left fairing i think it's the third one closest to rear of bike happened to mine put a new one in and it worked put the old one back in for the heck of it still worked I think the connection was just a little corrode try it before u put a new one in
sorry it took so long to update, school has been keeping me busy. it just so happens when I put my bike back together, the part that tells if the bike is upright or not (not sure what it's called, it's behind the headlights) was upside down. haha. so problem solved. ?
1 - 10 of 10 Posts
