1 - 12 of 12 Posts
Well i have a 05 600rr. I havent been riding the bike much at all...when i first got it i rode it everyday and everything was fine.
Fast forward a bit and i let the bike sit for prolly a month or so and found the battery was dead. So i threw the battery tender on it and it charged in about an hour..started up fine, so i took it for a ride and all was fine.
Again the bike sat for a few more weeks and the battery is now dead. I charged it withthe tender again and now its not holding anything..It started the first time fine and after that dead again. Im thinking its a bad battery....along the right lines?
**Throughout the time it was off the road i started it from time to time to move the oil and such..dunno if that killed it or not..
Ok so i just did some checking..with a voltmeter on the battery with nothing on it held at 12.59volts.
Went to start it and it dropped down to 6 volts while i was pushing the starter button, tried a second and it dropped to 3.5volts.
My guess the battery is toast
eeeeeee
Sounds like a garbage battery. Hondas are notorious for EATING batteries left and right, take the battery to the manufacturer and ask them to replace it. I believe most have a 4 yr warranty
yup i replaced the battery and it works like new..now curious what are the voltages i should be seeing at 5000 rpm?
K
BINGO! That battery's got OCS and it's done. needs replacement.
Stunt much?
K
at 5000 RPM with the high beam on, should be around 13.5 or more. less than 15.5 is the standard. but you';ve got to get a reading from Off and idle first.
No i dont stunt..maybe the previous owner did..
I checked it off it was 12.4v..on with highbeam at idle 12.9v and over 5000 rpm 13.4v
So it looks liek my charging circut seems fine and it was a bung battery..all fixed now..thanks.
Hi just out of curiousity what should the battery be at for each stage?
- Bike totally off
- Bike at idle
- Bike on with 5000rpm & high beam on
Want to make sure my battery is indeed o.k
K
- Bike totally off
- Bike at idle
well, just sitting, the battery should be above 12.6, but that's a relatively low charge state. ideally, 13.2 or so. what's important is that when you start the bike, you immediately see a voltage increase, and the same while testing it at 5000 RPMs.
Hey Knightslugger, here are what my redings showed. The dealership said it ws fine, but wanted to double check with you guys.
Static - 12.62
Bike off, lights on - 12.30
Bike on at idol - 13.12
Bike at 5k rpm with high beams - 13.95
K
bike off, lights on = not part of the test.
otherwise, looks good to me.
1 - 12 of 12 Posts
