1 - 9 of 9 Posts
Hey guys
I have a 06 cbr 600RR
Well All ready to go for the year have riden a little off and on, well first ride out a while ago I shut her off after riding a bit, and she would not start, so boosted it got her home, checked battery and charged it, she fired right up, well rode a little off and on around town, not problems that I know of, well went out tonight for some riding around town, had shut the bike off a couple of times for ifferent stops. Well bike seems to start harder every time I went to start it. I went home, shut her off and said heck try her one more time. No go, click ..click... click....
bad battery? same battery in it since I got the bike, had 5,000 miles on it, and now 14,000. I take it out and keep it in the house in the winter, I seem to play this similar game beginning of every year. Battery just had enough?
But me riding around would keep her charged even if the battery is on its last legs right?
Chances of it being the charging system on the bike?
regulator/Rectifier?
I hope not.
Would like to get this sorted out soon! With out going to a stealership
Thanks
George
Ok well I went out after doing some reading.
When bike is off battery volts are like 12.87ishV
started idling with low beam on over 13.5ishV (the walk from the garage to PC I for the numbers)
at 5k 14.6ishV
I did notice after let it run for a minute or so while check voltages, then I shut the bike off and batter will be over 13ishV, but I can watch it count down to like 12.86ishV
Would you all say the charging system is ok, regulator/rectifier?
This is the battery that was in it when I bought it in December of 06
Thanks
George
:+1: That sucker's giving up.
But before you bust that $125 out for a new battery, did you check your water?
Our batteries are small, and in the heat, or with time and heavy use, you can drain the fluid faster than you might think.
rip off that tab and take a peek, distilled water and a plastic syringe are significantly cheaper than a battery.
Good luck, my friend.
There's always bump-starting, too :bootyshak
That voltage difference is key man, your charging system seems perfectly fine.
Your battery is just giving out under load; that's what needs the attention.
So everyone would agree the charging system is fine? That concerns me more then me replacing a battery.
I can not check the water in the battery, it is sealed.
The battery is a YTZ10S MF
Original battery I am pretty sure, I never changed it.
Thanks
George
Damn, so sounds like I need to buy a new battery. But I would say 4+ years out of it is pretty good?
What is a good place to get a battery?
Thanks
George
Well dropped 120.00 at the dealership for new battery, good to go now. They load tested it and it was done for.
Thanks Guys
George
Sorry I didn't get back to you sooner man.
You got a pretty good deal; a battery from your dealer is sure to take care of you, and comparable ones from cycle gear would have ran you about $160ish.
Glad you got it going
1 - 9 of 9 Posts
