Hey guys I just installed my arrow headers and bazzaz z-fi + z-afm. I did the PAIR mod while installing the z-fi. Starting the bike there wasn't/isn't an fi light. I rode around for about 30min data logging with a clear map and the bike is at a complete loss of power (which i expected due to change in headers). After applying suggested values I went out to datalog again, this time I went out for about 45min freeway and street. The bike struggles to RPM past 7k majority of all throttle positions seem to make the bike bog more than actually accelerating. The bike sounds like it idles well but when riding she is like a 250cc or less. After checking the 2nd sessions suggestions the zafm recommended that numerous cells run at +50, or +70. It seemed to want me to add 36 to many of the same cells it suggested in the prior session. So far the zafm seems to want extreme suggestions that will only make the bike run worse (if that's even possible). I bought the zafm so that I wouldn't have to dyno but i'm starting to think I had too high of hopes with the zafm. I would really appreciate some help and advice as to what is going on or what I should do. The target AFR is set to 13.0 and at idle AFR is 16.0+.
2009 600rr used on the street. 91 octane. Arrow headers, hyperflo slip-on,
and z-fi/zafm
No one?
The bike struggles as soon as it hits the 5k rpm mark but I have no FI light. I've been checking my fuel line and it seems to not be as straight as I would like but I can't see the fuel line being the issue since the bike runs fine until 5k rpms. Please Help
Those values doesn't look good . Do you have your windows in english language?
The numbers in windows must be (i.e) 10,000.00 NOT 10.000,00.
I hope it helps.
