i have a similar problem. mine dies when i put the kickstand down in neutral. and sometime the neutral wont show up on the tach at all
Problem with the neutral switch. Check your connection to it. If I remember right, The connector is on the left side of the motor and is a one wire connector.
I'm having the same problem with a bike I'm working on for a friend.
If you guys figure this out, post up.
I'm also thinking it's the neutral switch, but the one I found on the right side of the engine is listed by Honda as a "Generator Pulse"
Any other ideas where this neutral sensor is?
