1 - 3 of 3 Posts
Since a couple of months when i steer for turning the bike(moving the front wheel on place) i got a noise coming from the front part of the bike..is like the sound of an old door run out of lube:poke:
Is there something that can make it?what lube/grease can i use and where?
Thx as usual.
When I first got my bike the brake cable was rubbing and making a noise like you described. I just kinda moved it around some and rubbed some chain wax on it with a rag. Haven't heard anything since.
Sent from Motorcycle.com App
Just to make other know, x-treme was in right. The "problem" was the tube covering the clutch cable rubbing on the frame. A little of wd40 solved it! Thanks.
1 - 3 of 3 Posts
