1 - 2 of 2 Posts
Rode up to a red light and the bike died. Pulled over. Tried to crank it over it tries but nothing. Oil is good. Battery is fine. Had a random guy come to help we tried to pop start it nothing. Opened the seat to look at the fuses one by one and they where fine and as soon as we put them back together it started to turn on. Got it home and that’s that. Not trying to ride it far till I know what’s with the bike. It’s a 14 with 7200k miles
Sounds like a wonky electrical connection, usually this turns out to be the ground. Follow the ground (black cable) from you battery to the frame and clean that connection with sandpaper. This is assuming you had no electrics at all.
If the electrics come on normally but it's just not starting, have a look at the starter solenoid connections.
1 - 2 of 2 Posts
