Okay so I did a coolant flush, I flushed the old nasty green coolant with D-water but removing the bottom drain bolt (by front sprocket) I did this till the water was clear. I then added some Tirox Ti cool coolant (about 1.5litters) and 3/4 of a bottle of water wetter.
At this time I did not know to drain the head coolant drain bolt.
So I poured roughly 2 liters of the Tirox coolant and water wetter.
Before I did this flush my bike was running at 173 consistent while riding, now it's at 177 but moves up and down a few degrees but never stays at a consistent temp. At a stop light it jumps up to a high temp quick!!
Anyone know what could be going on?
Get a service manual and follow the directions exactly.
You have air trapped in the system, it needs out.
Mike
well i did take it on a 2 hour ride. thats how i knew it was running hot. yesterday i took off the radiator cap off, and let the bike run for a little while but it still seems to run hot.
