1 - 3 of 3 Posts
I've checked all the threads titled "bike wont start" and tried almost anything. Do any of you guys have any insight on why my bike wont start?
Key in ignition in the on position, switched to start, in nuetral, kickstand down(or up). When i press the starter it sounds like the power clicks as if a fuse popped. I checked all the fuses and they are all good...
The bike was running, i turned it on and off maybe 5 times.
Then all of the sudden it stopped.
I was thinking maybe it had a short somewhere so i raised the tank again and searched but couldnt find anything?
Im getting clicks from these places. the bank angle sensor and the block in back... Then after that its like the battery is dead... then I notice when i wiggle the wires in the rear block the motor primes again and its ready to start but it just cycles, you hear a pop and then seems dead again.
D
Check your battery. The clicking you're hearing is the starter relay. With a bad battery that is not strong enough to spin the motor, the relay will click like crazy.
I think its the ground to the battery i just toggled the ground to the motor and it started again... its either the ground to the motor or the ground to the junction block.
1 - 3 of 3 Posts
