1 - 10 of 10 Posts
I was wondering if anyone had any ideas of what my problem might be. When I am on the highway my bike feels realy unstable. I checked the tire pressure and it is good. I checked the pressure because at some points it feels as if the tire is flat but it is not. Open to suggestions.
05 600RR..
define unstable..
Id say your suspension isnt dialed in for your weight.
Check for the balancing weights on the wheels to see if they are still there.
what IS your tire pressure?
how's the condition of the tires?
have you done anything to your suspension? whats your weight?
lets start there.
+1 on the tire balance... since you are there might as well make sure your rear wheel is properly aligned and your chain tension is correct
Lowering link maybe? Not sure if you lowered the back of the bike and not the front or if you lowered bike at all.
I bought the bike used but it only has 2000 miles. The treading on the tire is fine and the alignment weight is there. I was thinking I might have to adjust the suspension but wasnt sure. The bike is not lowered and when I first got it, it was running fine. Ive had it for a month.
My guesses would be asymmetric adjustment of the preload on the front suspension or misalignment of the rear wheel.
My front wheel is not shaking. I am going to try and get a alignment and see what happens. If it is still doing it I will try for a balancing.
1 - 10 of 10 Posts
