1 - 20 of 29 Posts
i changed the oil after winterizing it. woke up trying to go for a ride didn’t want to prime and after so many tries it worked and worked fine throughout the whole day and here we go again came home for 30 min and didn’t want to start once again. i figure out when i turn off and on fast it will pump but sometimes won’t start
Try turning the ignition on and off several times before cranking to let the pump prime. If this works, its fuel related. Either clogged filter or pump going bad etc.
the pump won’t prime. sometime it will sometime it won’t. if i flick the ignition off and on real fast it will work.
battery in good condition?
about year old. have it on battery tender throu the winter. like i said if i turn the ignition off and on real fast it will prime some time i works perfectly fine sometime it won’t prime u less i flick fast. once it runs it runs perfect pretty much
does your bike have HISS?
not sure what does that mean? check engine light or like flashing? is there a way i can post videos here? but no lights nothing just won’t prime. i have a decent video but can upload it here.
when it doesn't prime, does the FI and HESD light come on?
turning your key quickly has nothing to do with your problem, you're just looking too hard for patterns.
Then it's your kill switch, bank angle sensor, or engine stop relay.
I'm pretty sure the kill switch is white/yellow and black in the connector. Just put a wire jumper in the back of the connector and see if the problem persists
jump out the kill switch as i told you to do in my last post. it's either that, the BAS, or the relay. or some issue in that circuit.
can you explain it? i’m not that good with figuring out issues with bikes.i just know how to ride them haha.
Discussion Starter #17
i didn’t see this post. so inside the kill switch i’ll find the wires?
1 - 20 of 29 Posts
