1 - 10 of 10 Posts
ok i have a 2004 600rr i just bought. it was wrecked but it drove just fine and even started after i shut it off. 2 days passed whent to start it and it wouldnt even fire. so i sprayed in some starting fluid..nothing. so i pulled plugs and they are dry checked for spark nothing. i also dont hear the fuel pump.... i tried putting the kick stand up. put in neutral tryed out of nuetral tried holding brake tried holding clutch nothing....any help would be greatly appriciated.
Engine stop relay.
thanks for the info but turns out the gauge cluster plug in was a little loose and would not let the fuel pump or coils work. i found it very odd but glad i found the problem
I hope you are talking about the gray or blue quick plug on the left side of the bike....
1 - 10 of 10 Posts
