1 - 17 of 17 Posts
I have a 2006 cbr and my friend wrecked it about 2 months ago I finally got thing back enought to try and crank it but it wont crank and the fuel pump will not come on can someone please help me!
was the front end damaged?
check your tip sensor?
yes the front end was damaged i checked the trip sensor with the paper clip but still no fuel pump
new to me, how do you test a sealed sensor, in the upper fairing, between the headlights, with a paperclip?
D
Yes it is, and there is no way to test it with a paperclip, unless you tried jumping the harness with a paperclip but messed up and blew the 10A fuse.
D
Check the fuse. Jumping with a paperclip is an easy way to hit the wrong connector and cause a short.
these are classic symptoms of a BAS
D
Have you checked the kill switch?
What was the extent of the damage in the crash?
1 - 17 of 17 Posts
