Hii guys I have a 05 cbr 600rr iam rebuilding the whole bike. Stuck in some issues. Wiring is correct checked fuel line checked sparkplug checked everything is good even the fuel is going to cylinders I tried to start it cranks but doesnt start saw some huge backfire but didn't start. Directly poured some petrol into the cylinders and started it again spark going fuel ok wiring ok but wont start what do you think guys what may be the problem please tell..
Wiring checked ok
Fuel pump fuel line checked ok
Spark plug and coils checked ok
Side stand tilt sensor everything checkd neutral light, TP sensor checked,
Cranks but doesnt start
Please tell what could be the issue
Thankyou
225201
Moved to troubleshooting section.
As mentioned by @meatybeaty I would check timing and cam position sensor. Is it throwing any codes?
Reactions: Hanu76
No cam position no spark. So I wouldn't count on that.
Have you done anything in the engine at all?
I would suspect you may have the ignition coils connected in the wrong order if anything.
As your getting a spark and fuel , I would check your timing marks and then your Cam Position Senor and connector
Thankyou it was the timing. But the mystery part is according to manual given timing the bike was not starting.
But whe jumped ahead towards EX mark it switched on but I dont understand is it manufacturing defect
