I was swapping out front upper fairing and only disconnected the two main wires that connects to the gauge, did i blow or fuse or shorted a wire? FI light doenst come on and the MAL stays on and doesnt blink. I havent checked the relay or the fuel pump connector.. whats the first thing I should search for
Bank angle sensor is not hooked up correctly
its located in between the headlights make sure
the arrow points down
i removed it temporarily, like i said, I was swapping out front fairings, so u gotta remove the BAS to get to a screw bolt behind it which is attached to the fairing, im gonna work on it thursday, hope this works :crossfingers:
