Finally got new start switch and battery, bike will not start, it hasnt run in over 3 years because it was wrecked but never fixed. It still ran after it was wrecked but havent run it in over 3 years, not sure whats wrong. It will turn over, just put in new gas too. Any suggestions, please let me know. Thanks
When you turn the key on does the fuel pump prime ?
I'd continue to try to start the bike. it probably still has old fuel in the lines. if it's turning over that's a good start. we kind of have limited information here.
Yes its a low pitch noise but you should hear it loud and clear when you turn the key on 3 issues will affect the fuel pump
1. Bank angle sensor
2. Fuel pump relay
3. weak battery
2. Fuel pump relay
3. weak battery
I will add:
ECU, Engine stop relay and bad ground in the front harness (and not necessarily in that order).
