Ok, so my bike was running perfectly fine yesterday but one of the nuts holding the negative terminal on the battery came loose and fell off causing the bike to turn off. I took the battery out, got it tested and got new screws to hold it all on but it doesn't work now. I checked all the fuses and they are all fine and am out of ideas. Any ideas?
Thanks
Hey mate
Does it turn over
Does the fuel pump prime
Does it have spark
I had a nonstarter fixed this week, turned out it was flooded
gauge cluster doesn't come on at all when key is turned. fuel pump doesn't prime at all when switch is flipped. obviously no sound or anything when ignition is hit
Did you install the battery correctly? Neg to neg term and pos to pos term
Dud you check main fuse behind battery
Love simple fixes, unfortunately they're the ones we most overlook
