Hi
2003 model wont start after putting fuel in, i haven't put diesel in ..
rode bike home wouldn't start as soon as i got home. after a hour it started fine.
I have had a new battery put on 2 weeks ago running fine now the bike wont start from cold..
I have always had to hold clutch in before the bike would turn over now it turns over without clutch pulled in ..and in neutral
Could this be the problem.
Thanks
Discussion Starter · #2 ·
Just discovered when i moved the bike a feet feet the bike started ..
Is there a sensor that is playing up?
If you’ve always had to hold the clutch in to start it it’s probably the clutch pin switch but other areas I’d also look at are the side stand cutoff switch and be sure the neutral light works.
Discussion Starter · #5 ·
thanks everyone for your replies .
Put bike in garage now i will let you know what the out come is
thanks again..
Discussion Starter · #6 ·
Hi
Put bike in garage and found the power commander was faulty.
The bike runs like a dream..
Thank you everyone for your replies ..
