1 - 8 of 8 Posts
so battery was dead on it. push started great worked rode a round a bit no problem. left if for a week or so batt dead again tried to push start started seemed sluggish. let it sit for a min and just died. tried to push start and it kinda wanted to but no luck. hooked it up to a batt charger tried to start but it just goes likes its about to start. when i turn the key you can hear that noise i think the fuel pump activating but it just keeps turning over with no go. i tried
full throtle while tryint to start no luck
50% throtle while tryint to start.
i can do this about maybe 5-6 time before it drains the batt again.
what can i do???????? did i "foule" my plugs thanks!!!!!
Sounds like there isn't enough juice to spin the engine AND activate the injectors/fire the plugs. Time for a new battery.
yep u need a new battery.when i bought my bike it had been sitting in the garage for 3 months.u could charge it to keep the bike running but after a few minutes bike would die and then wouldnt restart off of battery without a charger
well seeing is how that battery will not charge if you dont ride it that is why it shuts off. the stator can not charge the battery in dile cuz its actually not creating juice to charge the bat.
you do have a dead battery and probably past the point where recharging it will do you nothing... buy a new one.
I leave my bat in 6 months when its put away and its starts like a charm everytime.
and if that dont work check your reg,rect it might have went toast on you
1 - 8 of 8 Posts
