1 - 12 of 12 Posts
Hello guys....Yes I stripped the oil drain plug bolt. Here are the pics. Any tips on getting it out? I know im going to need a new bolt but Im just trying to avoid taking her into the stealership and paying out the butt for them to remove it and do the oil change. Thanks in advance.
Do you mean the corners on the head got rounded or do you mean the threads of the bolt got stripped? If it's just the corners rounded then I'd try something like vise-grips or angle pliers. Just obviously make sure you are really clamped down on it before turning it so you don't round the corners off more.
When you get a new bolt installed make sure you get the correct size socket for it. ;)
if the threads arent screwed then the visegrips will work.
goto sears and they have tools to get the bolt out....
BUT.. how did you round them off... torque only to 22 ft #s... Shouldn't be that tight..
Ps. How much and where can I buy a new bolt? Does it have to be from Honda? Thanks. It felt like the right size socket I have no clue what happend.
I always put the new washer on (comes with filter) after every oil change, to maybe cut down on the risk of this happening..
Discussion Starter #11
Good advice. Well the new bolt is only $4 at the stealership....however they dont have any instock 3-5 day w t f =/
I looked on ronayers but it doesnt say. If anyone knows the size of this bolt then I can drop one in the mail tomorrow to him. Im thinking its somewhere around 10mmX1.25...Anyone know for sure? I wanna help this guy out.
1 - 12 of 12 Posts
