Went to the stealer and they wanted £300 to change the brake fluid for a CBR600RR-ABS. I have the workshop manual and decided to have a go at it myself. The workshop manual contains the full write up (and you must have it if you want to do this yourself). Having completed the procedure (and successfully tested the brakes), I thought I'd share my tuppence worth of advice. The link below allows you to download a pdf with a list of tools and parts needed, and the tips and tricks (with pics!) I learned in the process:
http://s000.tinyupload.com/?file_id=63011958797666636711
Enjoy
roadracer76
Enjoy
roadracer76
Do you still have this pdf file As this link doesn't work i would like to bleed my abs breaks
