1 - 8 of 8 Posts
I'm planning on changing my brake lines and was wondering how much brake fluid would i need for both the front and back
I have the belray super dot 4 12 fl oZ is that enough to do both front and back brakes?
Usually one bottle should do, but it all depends on how much you use to bleed and to get all the air out. I would get 2 just in case. If you use less than what you purchased it, then return it.
Post Whore Extraordinaire
ive done a whol ebike with 1 bottle and had some left, but i was also using a bleeder, so i dont knwo how much more or less is needed to do it old school
Dude, just try it and you'll know. We can't predict whether you bleed it correctly or if there's any leak to say that it's enough.
1 - 8 of 8 Posts
