BOTM Winner 02/15
So I got an HRC starter/killswitch for my 03/04 CBR600RR which does not have a built in brakelight microswitch contact, it is also missing half of the pins compared to the OEM right side switch as you can see in photo.
Now I ghetto rigged my Microswitch so that it can fit into the head but I'm not sure on which spots I should place them... I've got a black and a brown wire coming from the RCS19 micro switch.
Here are some pics to make it more clear:
HRC Connector:
OEM Connector:
Micro switch wires
Does anyone know in what spots the micro switch wires should be and what about the other empty spots, will that be a problem? Oh yeah, I already checked my maintainance manual but I cant figure it out.
The only thing I noticed was that the "Black/Yellow" wire coming from the right side switch is not assigned to the killswitch nor the starter. So I'm guessting the brake light switch has something to do with that wire.
the wiring diagram I looked at says you'll have to match them up with the White/Green and Green/Yellow wires on the main wiring harness
edit: this is for a US wiring diagram, not sure if yours is different or not
BOTM Winner 02/15
Thanks, any idea which wire should connect to which of the two?
