1 - 2 of 2 Posts
so heres the deal, my front brake lever does not come far enough forward after using it to release the micro-switch. The brake light then stays on until i push the lever out about 1/2 inch. is there a spring or something that needs to be replaced so the lever is released all the way.
any ideas
might want to lube the lever or take the lever off the perch and clean it. Bolt on the lever may be too tight also not letting it rotate freely.
1 - 2 of 2 Posts
