Can somebody please provide me a picture of their brake oil holder next to the right handle bar? I think mines off, just want to make sure...
brake fluid...
but what year?
its different 03 - 06 and 07+
Reactions: xWaNgStAx
What do you mean by off?
As far as the fluid is concenered, for the most part if the fluid level is between the upper and lower marks when the bike is level, you should be ok.
If you do have an issue, it may be more efficient if you post a pic of your brake fluid resevoir and we'll let you know if there's anything wrong:)
Banned
There is a rubber diaphragm that fills up the empty space to prevent air from combining with the fluid. Remove the oil cup cap (called oil cup in parts fiche) and then check the brake FLUID level.
