1 - 8 of 8 Posts
What's the best brand?? I usually order Vesrah brake pads from kneedraggers but they're out of stock, any vendors here sell em? I actually only need the front brake pads, i still have a spare rear.
vesrah RJL's are great pads. you'll be hard-pressed to find a better "do it all" pad. i've had mine on for 10,000 miles now and they're only halfway down the wear bar. and i brake quite hard A LOT. almost all those miles were in the canyons, and they've also seen me through 5-7 trackdays with no problem at all. use with stainless lines and good fluid to get the full effect of course. good pads without lines are useless. lines are more important than pads- especially on the track.
Newbie question but what's the best way to tell if you need new pads, guessing looking, how to look? Thanks
they have wear bars. when you can't see the slits in the middle of the pad anymore, then they need to be replaced.
Post Whore Extraordinaire
If you're running ss rotors, you won't find many better than Vesrah RJL
I'm hoping to try iron rotors with organic pads sometime soon tho.
1 - 8 of 8 Posts
