Need a little help. I want to know if its possible to adjust my rear brake pedal. I would like to move the lever down just a little bit, so its easier for me to reach without having to reposition my foot. I looked in the service manual, with little luck. Just wanted to ask before I jumped in. Any help would be great.
Thanks.
Resident Leg-Humper Females Beware
yes it is. there's an adjustment nut on the bottom of the master cylinder. should be able to loosen it and adjust it kinda like the shift lever.
loosen the 12mm black/brownish colored nut and then kind of hidden under the boot upwards of the 12mm nut, is a 10mm silver nut. turn that to the desired position and retighten the 12
hope that helps
Also check that your rear brake light works correctly after adjusting the pedal. The switch will have to be adjusted as well.
