So last time I changed my tire, when I put the rim back on, the brake pads were too close. I put a screw driver in between the pads to push them further apart. After, it was still a tight fit but was able to get my rotor between them fine again. But now, the rim seems to not spin as freely as it used to (pads squeezing too hard) and I was able to pull the lever almost into the bar. Thought maybe I somehow pushed some air into the system or just messed something up. Drained and re-bled the entire from brake system. Now the front wheel spins like it used to but the lever still pulls in a lot further than it feels like it should. I have my lever set to all the way out but still can almost touch the bar. Also feels like the brakes aren't actually engaging until the lever is pulled in an inch or so. Does it sound like I may have messed something up? Possible hurt a seal in the MC when I pushed the pads apart?
