1 - 20 of 22 Posts
you can jump it from a car make sure the car is shut off very important
Ceph
very well said bro MR Watts ( new nick name )
Ditto on NOT starting the car. Otherwise perfectly fine
im jumped my quad off with the truck when i first git it (quad) and no ill effects to this day, the truck was running but i also pulled the cabels off as soon as the quad started. if youre in a pinch theres nothing wrong with it. 12 volts is 12 volts no matter how you slice it.
12V=12V
But yeah, transients from th altenator will toast your bikes electrical system $$$. Just leave the car off, jump as per normal....good to go.
guys listen to MR WATTS he is full of charged wisdom
2006 BOTY WINNER
All we use in our shop is a car battery(remote location jump starter), never have the car running, and an ATV has alot less electrical componets than a modern sport bike. It could cause all kinds of ECU problems.
is there a large difference in the current in a car vs. a bike? Voltage can be the same in both obviously but the current is another story. possibly that could pose the problem.
Impreza The Impressive
Opps.. i just got done jump starting my bike with my car running... i had the car on for about 45 secs before i took the cables off of the bike though, will that still create a problem? when i took the cables off the bike was still running however it sounded like it was gonna die.. how long do i have to keep the bike on until i can turn it off or how do i know that the battery is fully charged? i got the bike back from the impound where it was stored indoors. the battery just needs charging and i was wondering how to do that? thanks
1 - 20 of 22 Posts
