1 - 20 of 23 Posts
Okay guys, I had another thread floating around about white smoke...i think i found a really good clue. When i first had the bike, the oil level in the inspection window was at 3/4 full, and after about 300miles, its almost at the halfway point....but i can tell its has gone down. I started to smell the burning oil on my clothes...so I wouldn't say I'm super concerned, but I do want to take care of this before anything worse may happen. What can I do to check into this problem to find a fix?
Bump...now i know for sure the bike is buring oil...but i rarely see, if any, smoke coming out of the exhaust pipe. I honestly don't know the history of this bike from the previous owner, but i don't think the problem could be a head gasket, since upon receiving the bike, it had really low mileage and the fact that i don't see much smoke or any problems in performance. I'm going to go out on a limb and say it might be piston rings, or the valve seals...that migth be causing this oil to be leaked somwhere in the combustion chamber. Any suggestions in how to pin point/problem solve this situation?
how many miles does the bike have?
There are really 2 solutions: Fix your engine, or buy a new one.
Fixing - Min $250 for head gasket and all the bolts and o-rings that will need to be replaced upon tearing into the engine. Plus parts (pistons and rings are about $500) Valve work, I have no idea the $. Countless hours of cleaning and assebly to do the job right.
New engine - I've bought one for $600 and have seen them go for $1000 or more. EBAY
New pistons and rings with the other parts looks like about $750.
Valva job would be cheaper and a lot less work ($ = headgasket + parts)
If you think it might be the valves, I'd look into it. If you need new pistons, I'd look into another motor.
Bought the bike with just under 6k miles. It has about 1.5 k since i bought it. Coolant levels are fine, oil level seems to vary since i know its burning oil. I honestly don't know what the cause of the problem is, so i might just have to bring it to a shop(since i don't want to take it to the dealership) and have it go under a compression test. I guess i'll go from there and see what happens. If it seems to be a problem...i might just sell the bike, and get something else...=( I don't want this bike to be a money pit like all my other car projects.
How about a simple compression test and upon the results
determine the course of action ie do not speculate until
your sure of the problem
All 3 solutions will be expensive if you take it and have the work done.
The compression check will tell ifit is piston blow by. If the pistons are good, has to be the valve seals.
For my own interests: What year bike and are you in Ohio or Cali?
I'm in CA and the bike is a 06 with about 7300k miles. I was planning on doing the rebuild myself, depending on the severity of the problem. I'll get the CT done, and if it is leaking, well the leak down test will follow..i'll keep you guys updated.
Cool thanks..i'll let you know after what happens with the CT. I'm usually down in redondo beach so it be closer for you anyways.
Just a side note, I have an engine that I was thinking about re-building but I really don't have the time and min $300 in parts just to put it together not including re-build parts. The heads are fine and I'd have to check the pistons. Engine has 2.5k street miles.
Discussion Starter #11
Cool! thanks for the relay of info. I'll let you know what happens. I'm just really busy with school right now, so i can't really get anything done till the weekend at best. Are you willing to part that engine? What year did it come off of?
Edit: BTW does anyone know any reputable shop around the san fernando valley? I just want to get a compression test. All the shops i've been to look a bit sketchy and not for the faint of heart.
So i've been checking my oil level regularly and it seems as if it is going down. I'd have to say in about 2weeks, riding ~300-400miles, my level has went down from near topping off to about 1/4 oil left in the inspection window(keep in mind that it is still in the "okay" area. I usually check the oil after about 10 minutes of not running, and then i'll check early in the morning when all the oil has drained down. I think what i'll do is remove the lowers this weekend and see if there is any dripping of oil, then i'll probably change its oil and put on a new filter, and new drain plug gasket..and see where it does from there.
^ good idea bro
1st ... id take off the fairings and do an inspection to see if there are any loose bolts that oil could leak out from (if i were you . i would take a wrench and tighten all of them just to be safe)
2nd ... after tightening all the bolts . do the oil and oil filter change change
3rd ... take note of your new oil level ... go ride and then check again .... if the level goes down then i think there are problems with your pistons (i hope im wrong and that there are nothing wrong with your bike)
4th ... if the oil does go down .. ill take it to a reputable shop and get a compression test
5th ... do all of those stuffs i mention ... give the result ... all the good ppl here and i will try to help you out on what's next to do
good luck bro
THanks...its not like a dramatic drop in oil level..it just happens over a course of a couple weeks. So i don't know. I'm just hoping its leaking from the drain bolt or something...i'll have a look at it later..and keep you updated.
Discussion Starter #16 (Edited)
^just an update...i still haven't had a chance to get any compression test done....but came upon this thread as i was in my search.....
http://www.600rr.net/vb/showthread.php?t=12295&highlight=oil+burning
As of right now, i'm just really unhappy with the bike, and am considering trading in spending a bit more in financing to get a bike that wont go to downhill on me. I hope things can get fixed(under warranty) in a reasonable amount of time....or I will be forced to trade in...right now my faith in honda motorcycles is diminishing....
D
If you're getting white smoke, you're not burning oil. Oil burns with a blueish tint. At around 7,500 miles, the rings shouldn't even be anywhere near bad condition to allow oil to pass. It is possible that maybe the oil control rings on the pistons broke, but highly unlikely.
As Ngyun said, pull the fairings off of the bike, but start the bike up and let it idle. If there is an oil leak, you should be able to find it. My guess is either your drain bolt is loose, there's a small hole in the filter, or a leak somewhere else around the pan area. By any chance have you done an oil change and removed the oil filter by stabbing a screw driver through it? You might have nicked the oil cooler if you did and it could be leaking.
Don't run the bike with less oil either. If you've been doing that for a while, and it was like that from the previous owner, the rings may be damaged/worn out and letting oil pass the piston, but as I said before, it'd be blue smoke.
Discussion Starter #18 (Edited)
^thats a negative....its hard to say with the smoke..since its only happening after running awhile in the twisties...and doesn't happen at idle ever. I'll pull the fairings, but i haven't seen any oil marks on inside of the lowers(other than the normal road grime). I always refill the oil back up to par...first time i refilled, i used 100ml this second time i used 400ml to refill. As far as th oil filter is concerned, i just used an oil filter wrench to remove.
Edit:
i"ll probably try and pick up a compression gauge tester today and give that a whirl, also probably checl the plugs today.
Discussion Starter #20
Yup...its not from an oil change....on decels, smoke just poofs out. NOt sure if you read that link i showed you, but the user NewRedRider stated that the poof of smoke was actually fuel being dumped...that might be the case, but i still lose oil somewhere.
1 - 20 of 23 Posts
