1 - 20 of 28 Posts
I know this topic has been covered many times,but as I’m new to 600cc I’m trying to do all my own maintenance etc. I’ve read a great deal on the cct sticking etc,but what I need to know to check mine is once I take the 8mm bolt out of the end,can I just wind the tensioner in with an appropriate screwdriver (assuming this is clockwise)then just pull the screwdriver out and let the tensioner pop back out in to place or is it not this simple?
Are you taking about using an OEM tensioner, or an adjustable tensioner? An OEM tensioner will come with a little locking pin already installed, so it keeps the tensioner pin in place.
Unless you hear excessive rattling coming from the throttle side (the side with the CCT) around 3-5k RPM I don't know that its worth checking.
A lot of screwdrivers are hard to fit in the space where the CCT is mounted. With the CCT off the bike, you can definitely fit smaller screwdrivers in there so the dimensions of the flathead are typically right. You can cut your own tool out of some scrap metal if you have it available, its just a long flat piece with a square head to lock the CCT. Try searching for CCT tool dimensions on google with site:600rr.net. Someone measured it out for people who want to cut their own.
I do not recommend just yanking the screwdriver out with the CCT fully retracted and unloading against the cam chain with full force. Release it slowly or if you already yanked the tool just retract it like a half turn and let it back out slowly. The point is to have the tensioner come to rest on the chain instead of unloading the full force of the spring into the chain. Some people might think this is wasted effort or not entirely true but that how I treat mine. In my mind the full force of the spring unloading from full unwind may slightly over-tension the chain.
Discussion Starter · #4 ·
Yes the oem tensioner,I was going to check mine is working/tensioning correctly by winding it in a little then releasing,but I suppose the best way to check that is by removing it and checking?
Like G money said you would be wasting your time to remove the tensioner and "check" it.
The best way to check it is to start the bike, and rev it lightly while listening for a rattle in the area of the cam chain.
You will know when your cam chain needs replacing. Don't waste your time doing pointless work.
There is nothing to check. The tensioner isn't failing as in its not applying tension. The rattle is literally just an annoyance.
Reactions: SaratogaLED
I think your interpretation of what you read about the CCT may be slightly off. I don't see how the tensioner could be "sticking". The contact point is getting coated in oil from the cam chain unless your oil is sludge in which case you have bigger problems.
Like bored&stroked said, a bad tensioner doesn't apply enough tension. Or like I said in my original post, you've slightly over-tensioned it by allowing it to unload rapidly from fully retracted position.
The best way to check is slowly increase the revs to 5k while listening to the right side of the engine. Unless it sounds like you're chewing rocks its fine. I replaced mine because I thought the chain was loud and the new OEM CCT did nothing for the noise if that makes you feel any better. Post a video with good audio if you really think it needs replacing. Or search for videos of bad CCT on 600rr.
It will rattle somewhere between 3000 and 5000 rpm. Some are much louder than others. It is not an issue of tension on the chain it is the tip of the plunger resonating back and forth making a racket at certain RPMs. You can take the CCT out and spread the pin that the plunger rides on to quiet it down but the CCT is a PITA to get to.
I've ridden for years with a stuck tensioner. It's loud as hell, and potentially very dangerous. What is the purpose of the tensioner? The purpose is to apply tension to the cam chain, if the cam chain skips a tooth, your engine is immediately out of time, and you could be looking at a real fkkkkd up day.
Sure the tensioner is a pain in the ass to replace on 2007+ but it is not impossible. Don't bother "checking" it, just replace it. Myself I replaced it with another OEM "automatic" tensioner, and to this day so far so good (even though I didn't get both tensioner bolts equally tightened).
I was also one of those that read too many "excessive cam chain noise" post's and maybe I was one of the lucky ones. I replaced mine about a month ago at 24k miles, honestly it made very little difference. The old tensioner's spring resistance felt identical to the brand new one even with all those miles on it. I already had mine opened up checking valves, replacing spark plugs etc, so of course i went ahead and replaced it and don't feel like i wasted too much time. I guess now i have the peace of mind though.
Discussion Starter · #11 ·
Thanks guys
I think it’s the “peace of mind”thing,but I’m going to leave it alone!
Thanks
Thanks guys
Thanks
Yeah, I mean if you aren't getting the rattle, or bag of marbles sound, then of course leave it alone, it is working fine. The less things you take apart the less things you could do wrong putting it back together. General rule of thumb when working on bikes, cars, etc...
I think you should just enjoy your bike. If you have to question if there is a problem, and can't tell if there actually is, you might just be nit-picking. It's just a motorcycle, and it won't last forever. Enjoy the hell out of it, ride it, and don't think twice about a little tick or rattle here or there. If there is a serious problem it will be obvious, and you will know for sure without having to ask anyone.
You may not know what the cause of the problem is, but you will know there is a problem - you feel me?
To date on all your threads, your bike appears normal to me. Now stop making excuses and get out there and ride it.
Discussion Starter · #15 · (Edited)
Gotcha mate,that’s what I’ve decided to do,ride and enjoy ?
I am going to replace the ctt with an oem automatic,but after a few replies to my thread stating don’t just pull the key/screwdriver out on the retracted adjuster and let the adjuster out at full force onto the cam chain,but isn’t that what the special key is inserted for,to bolt on the tensioner housing and release the special tool once bolted down?
Hey have a look at your service manual, their available online. Full of information on all the parts and how to access, replace etc
https://ownersmanuals2.com/honda/cbr600rr-2004-owners-manual-60891
It's a common noise, just recently noticed it myself. Beginning to think it's normal. So i took a video of my bikes sound yesterday and noticed it sounds very similar to a video that was taken 2 years ago, I know. So got me thinking, i hadn't been on the bike for a few months and was probably paying more attention to the exhaust sound over the engine and a combination of other issues meant i was looking for problems, have to admit.
if it helps, mine sounds exactly the same. Does the sound fade slightly when pulling the clutch..just curious?
Anyway Enjoy
Discussion Starter · #17 · (Edited)
Hi
I’ve tried pulling the clutch and it’s still there (obviously a slight difference when a clutch is pulled on any engine)only on cold start for approx few minutes and goes once fully warmed,I can’t hear it at any rev range while riding either,so just cold start ups at moment
Sounds good man. Here's a link to a video of my bike uploaded today which sounds the same, just more close up. If it helps re assure.
Anyway timing could not have been any better, i don't know anyone with a Cbr to compare my bike with and your video / thread confirms everything is okay, cheers for that..
Discussion Starter · #19 ·
No worries,glad it’s helped ease your worries,it sounds identical to mine. When does yours rattle,cold or when warmed up,just curious now ?
Sure, it makes the sound when cold and hot, The video was taken on a cold start after doing some work on it. Just more noisy when the engine has warmed up and idle that's all
I'll be passing by a local motorcycle garage this week to have a quick word about a few other things, Lets see what they have to say about this noise, No harm in asking. ill keep you posted if it helps. Although wouldn't worry if i was you..
Worth mentioning my bike has over 25k miles, used on a track few times. Fact it sounds identical to yours, really gives me peace of mind..Although in my case could easily be the valve clearance requiring adjustment soon. Honda recommend every 16000 miles
Also remembered, bike went to get a MOT 2 months ago. An MOT (Ministry Of Transport) is required by law in U.K before using a vehicle on the road. We need this certificate before applying for insurance, tax etc basically a certified garage will check over the bike making sure it's road worthy, stating any issues at the same time. Anything serious and we aren't allowed on the road, quite strict and no mention of the sound which further confirms everything mentioned above ;)
1 - 20 of 28 Posts
