With the oem automatic,there is a key included/already fitted,do you unwind it gently once the tensioner is fitted or just pull the key out and let it set itself
If the key is in the tensioner it should have been turned clockwise to retract the plunger, if that is the case fit a new gasket put bolts in and tighten up to correct torque , remove the key and install the tensioner cap bolt with O ring , tighten up
Yes it’s fully retracted,so it’s fine to pull key out and let the plunger shoot out on it’s own?
