Can I use the cylinder head of 03-04 for 05-06?
246 Views 5 Replies 3 Participants Last post by  NewRedRider
same PC37 model but It seems to be divided into the previous model and the later model.
anyone knows?
Part number is
12010-MEE-000 HEAD ASSY., CYLINDER -------> 03-04
12010-MEE-D00 HEAD ASSY., CYLINDER -------> 05-06
Reactions: 1
You're starting a few threads related to your engine so you may want to consider an engine build thread to keep everything concise
Reactions: 3
What should I do? I want to follow the rules here.
Reactions: 1
You're not breaking the rules per se, but, if you start a thread like "Kimchi Rider's Engine Rebuild" you can update the thread as you add more pics and go through the teardown and you can bump the thread if you want to ask questions on which parts to use or other advice instead of multiple threads each with a bit of information.
Reactions: 2
oh, i got it. i will do it!
Reactions: 1
2
No worries Kimchi Rider!
Mr. Cannon is just trying to steer you in the right direction. American's tend to forget where we put things so we like to jam everything into one junk drawer in the kitchen.
The Mod team can also merge several threads together if needed.
