1 - 2 of 2 Posts
Ive got my bike TOTALLY apart for a frame swap because my title is a non repairable title... my question is im stuck at the airbox... is there a way to remove the airbox without exposing too much? im trying to keep the motor in tact as much as possible so i dont have to mess with it anymore than i need too... I searched and didnt find anything but pictures with the airbox already removed... is it just the phillips screws around the edges and then its fastened inside the box to the motor?
There is a really good removal procedure in your service manual, and I hope to hell that you have one if your doing a frame swap!
Getting it off is a bit of a PITA but its not difficult. Just make sure that you block the throttle bodies off with a clean rag cause the last thing you want to do is drop something in there or get dirt in there.
1 - 2 of 2 Posts
