1 - 8 of 8 Posts
Hey Guys, i'm trying to fix my bike back up after a spill in april at the track that put me out till now(broke tib and fib in left leg).
I finally got around to start to fix the bike.
I've been looking for the 'swivel' screw that connects to the shift rod but with no luck.
Anyone know where i can get it?
I looked at OEM parts but it doesn't have a part number. It's also not one of the replacement parts available on the woodcraft site.
I have an 03 600rr and i have the woodcraft CFM rearsets.
I'll post up a pic of what i need to replace.
Thanks!!
Go HERE:
http://www.mcmaster.com/#rod-ends/=8js0za
Select "ball joint rod ends" (second option), then select
-High strength (first option)
-Male shank
-Right or left hand thread (I doubt it's left)
Then your threads are either M6x1 or M8x1.25
These two will either have a 6 or 8mm diameter hole respectively, which should work for you.
The item #s for those are 59935K82 or 59935K83
You can bulk up on any other stuff you need here too.
An alternative route is getting a "Ball Joint Linkage" type rod end, which already has the stud sticking out of it on both sides.
McMaster RULES.
thanks!! that was very helpful for the future man!!
btw i ordered some replacement parts from woodcraft for the rearsets and asked them about it. They threw one in for $12 :)
1 - 8 of 8 Posts
