the right side goes on having trouble with the left. the bike has been dropped on the left please help.i am missing the screws that hold the headlight in place but have them coming from honda tomorrow.
http://www.600rr.net/vb/attachment.php?attachmentid=18803&stc=1&d=1297121596
http://www.600rr.net/vb/attachment.php?attachmentid=18801&stc=1&d=1297121596
this is where i am missing the screw
http://www.600rr.net/vb/attachment.php?attachmentid=18802&stc=1&d=1297121596
http://www.600rr.net/vb/attachment.php?attachmentid=18800&stc=1&d=1297121596
this is where its not fitting ^
http://www.600rr.net/vb/attachment.php?attachmentid=18799&stc=1&d=1297121596
when i get it to fit on tank its not fitting in the front^
are you sliding it in the front properly with the tab. When I have trouble with mine, which is similar to that actually, I have a friend hold the front tab in place while I push the side upper into the tank and then make sure everything is fitting properly. Possibly those screws are not holding the front down properly without the screws...
only things I really can think of, hope that helps any
front tabs on upper cowling slide into nose slots last.
upper cowling starts w/ fit to gas tank cover,then rotate down and fit rest of the [email protected]#$%^ tabs straight in from the side.
the front tabs will slide into place w/a smooth push from the palm of your hand towards the nose piece.
use a bit of silicon lube or wax to make stuff slide/fit better.
be careful fitting all the little tiny flat blade tabs and look at the underside of the cowling as you fit it to the black underfairing piece.
ABS cement can fix broken tabs.
thanks for the help gonna wait till i get the screws to try again let you know what happens post up some pics.never had problems with my gsxr like this too many tabs wth.
