Does anyone run an 07 cbr600rr and have done just a cat delete link pipe and not got a power commander, auto tune, ecu flash and servo buddy. Will the performance be crap if I don't get all those or is it ok to run it without and just delete the cat with the link pipe
The cat doesn't restrict flow, so removing will make no difference in power or MPG. Main benefit of full titanum exhaust is weight savings.
It's actually modifying fuel & ignition maps that gives you performance boost. That will you bump in performance with zero hardware changes.
I have a 2012 and I'm running an Akrapovic Slip On with the Toce Link Pipe. I had the bike custom dyno tuned, they didn't give me before numbers but it put down 106 hp. I didn't notice any significant change in power, but it saves a little over 3 lbs and makes the bike a bit louder.
