Only CA bikes have a cat. You have nothing to worry about. And yes, a full system would eliminate this.xp1ik05 said:stupid question but where is the cat on a bike??? would a full exhause already eliminate this??? i have a slip on but i dont see where it would be....
We need to clarify some things here. The general concensus is that all 05+ models have cats, CA or not. The 03-04 non-CA models have a buldge in the collector(2 actually) which is a resonator. If it indeed was a cat, you would have an O2 sensor for closed-loop feedback which you dont! The buldge on CA models is a pre-converter which is used to start functioning(reduce emissions) during the warm-up period, as it's smaller in size therefore heats up quicker. The 2nd purpose is to pre-heat the exhaust gases so that the main converter reaches operating temperature sooner. The point, you wouldn't have one without the other.tek said:um no... not only CA bikes have cats. CA bikes may have more than one cat, but this i cannot confirm.
my 06 CO bike had one, as has every other rr i have seen. on the 05-06(i believe) the cat is right by the midpipe connection, in fact if you take a flashlight and look down the pipe(with midpipe off) you can clearly see it
now for benifits... i really don't think there are any. the cat is really well designed for high flow, i can't see any benifits from knocking it out other than for tuning.
but you can search on this and find TONS of info. search for gutting, cat, converter, etc. its been argued and thought about a lot
whoops, thought you had an 03-04. Here are the cats circled. Its the big one people gut out...xp1ik05 said:stupid question but where is the cat on a bike??? would a full exhause already eliminate this??? i have a slip on but i dont see where it would be....
I bought my 04 someone cut all the oem exhaust out to the header. How can I replace all this.We need to clarify some things here. The general concensus is that all 05+ models have cats, CA or not. The 03-04 non-CA models have a buldge in the collector(2 actually) which is a resonator. If it indeed was a cat, you would have an O2 sensor for closed-loop feedback which you dont! The buldge on CA models is a pre-converter which is used to start functioning(reduce emissions) during the warm-up period, as it's smaller in size therefore heats up quicker. The 2nd purpose is to pre-heat the exhaust gases so that the main converter reaches operating temperature sooner. The point, you wouldn't have one without the other.
In addition, a back-to-back dyno has been tested with and without the cat. The end result was different fuel maps and gains throughout various areas on the powerband. :icon_salu
what do you mean? is there no tailpipe? what about cat and exhaust valve?I bought my 04 someone cut all the oem exhaust out to the header. How can I replace all this.
There is nothing just open headerwhat do you mean? is there no tailpipe? what about cat and exhaust valve?
then aftermarket is probably your most cost-efficient route. You can probably fit a ready piece called midpipe, and an aftermarket tail...or go full..There is nothing just open header
