Hi
My bike just clicks doesn't start I have changed stater motor, stater selnoid, fuses, new battery , even then it just clicks does not crank. Please help
check the starter relay ground by:
1. Disconnect starter relay 4-pin red connector.
2. Shift transmission to neutral.
3. check for continuity b/t green/red starter relay wire.
4. Should show some continuity on ohmeter since the diode is in the circuit.
Also check the two main leads for continuity and the yellow/red wire for continuity when pressing the starter button.
