Couldn't find the correct subform under technical so I put it here. Move it if you know where it should go.
I received my new fairings from cbrfairings.com. I tried to get the windscreen mounted to the front fairing but I can't get it to fit.
There are little tab like bits on the inside of the nose that the windscreen is supposed to sit on. The screws are in and lined up but the bottom of the screen sits well below those tabs causing the windscreen to protrude to the inside of the fairing leaving a nice gap between the fairing and the windscreen. I could sand the little bits off and get rid of the gap but then I think the windscreen would sit too low and the "third eye" light won't fit.:banghead:
Anyone run into this?
Pics below (sry they're so big)...
