LET ME START BY SAYING I DO NOT WORK ON MY OWN BIKE, THE SHOP I BOUGHT THE BIKE AT HAS THAT PLEASURE. THANKS TO A PRE PAID MAINT. PLAN. ANYWAY WHEN I PICK MY BIKE UP I GIVE IT A ONCE OVER, WHEN I GET HOME TO CLEAN AND WAX THE CHAIN, I SEE THAT THE RIGHT SIDE ADJUSTMENT BOLT IS NOT TIGHT, I CAN TURN THE BOLT BOTH WAYS, I HAVE TRIED TO TIGHTEN IT BUT WHEN I CHECK AFTER MY RIDES,THE DAMN BOLT HAS VIBRATED LOOSE AGAIN?????HELP
Check two things:
Just snug it down slightly harder by turning the bolt clockwise until you compress the collar you see on the bolt slightly.
or
Make sure you are tightening it down the correct way (clockwise). There is a collar that is supposed to absorb the vibration and prevent the bolt from vibrating loose, but it isn't utilized if you are tightening it on the other side (by turning counter-clockwise).
Hope this helps,
Dan
i dont think it can come out, so just snug it up and dont worry about it
yeah, but try to keep it tight just in case
