1 - 1 of 1 Posts
Hi guys,
I'm new to the form and would really like some help.
If I have posted this in the wrong section please forgive me.
When I back off my accelerator I get like this bad slapping noise on the right side of the engine.
I pulled off the covers and removed the clutch. The timing chain and guides look perfectly fine and so does the tensioner. However i see that the oil pump drive chain has quite a bit of slack, is that normal? because the guides done look worn at all and the gears look fine also.
What could be causing this noise?
Thanks in advance.
1 - 1 of 1 Posts
