I have alot of wax overspray on my rear rim, and wondering if anyone has had a problem removing it. I was thinking about rubbing alolchol? What u think?
What up I just cleaned my chain last night... I had a little bit of overspray on my rear rim also, just grab an old t-shirt and wet it... Wipe it down really good; I realized that trying to using any type of stronger chemical cleaner will start to strip the black off the rim...
WD 40 will disolve the chain wax. However it will not wipe clean off the wheel. It still looks smeary if that is a word. I use WD to remove the gunk the the honda polish to clean it after that. Looks brand new!
· Whoring Is What I Do
Just a little helpful hint..cut out some cardboard, slide between your chain and rear wheel, then spray your chain, it helps elminate any over spray gettin onto your wheel.
